Just a thought for the gearheads (engine change up)
This is just a thought. I will max out my combo first then step up bigger. I have an 01 f body and it has p&p 241 heads and a comp custom grind. I will post up specs further down. Here is my question, will I benefit from a set of TFS 215's and one of the G5X.. from LG or one of the VRX grinds from Vengeance and by how much? What would you reccomend? The car is an auto car with 3.73 in the rear. It has gone 11.85 with a 1.70 60 ft and it was spinning in the first 20 feet. This was on motor. Here are the specs.
2 146/111
.3 201/146
.4 251/182
.5 291/203
.6 301/219
.65 304/223
stock valves, milled only to clean up surface
.030 Cometic gaskets for tight quench
230/240 .613/.608valve lift .361/.358 lobe lift 111LSA Comp Cam
2 146/111
.3 201/146
.4 251/182
.5 291/203
.6 301/219
.65 304/223
not sure how worth it would be for the cost....nearly $3000 by the time you get the rockers.
and your cam is plenty big.
that's alot of money and work for 15hp
might be better off with a FAST intake for the setup.
don't spend $2,000 - $3,000 for mayyybe 10-20RWHP
you might bust the motor and take out that new big $$$ top end
92/92 ported from Ragin Racin $1400 for a solid 20 RWHP and you can transfer it to the next engine
