Motor finally finished; Suggestions/opinions?
Finally pieced the motor together!
LS6 heads ported, polished and shaved to 59cc combustion chambers, LS6 intake manifold, 42# injectors, Diamond racing flat-top pistons with 2cc valve reliefs, Total Seal rings with the top ring at .020 and the bottom ring at .016, Eagle H-beam rods with ARP2000 bolts, 239/242, .649"/.609" cam with 111 LSA, stock stroke, stock bore. Before the rebuild I was spraying a 200 shot with just the cam and landing in the high 11s on ET Streets (at 7000ft... I see guys at sea level getting these times on a cam alone which depresses me) every weekend for about a year with no problems.
Now my questions are...Is it safe to push a larger shot? I think a 200 is great and has proven safe and reliable but a 300 just for grins every now and then wouldn't be all that bad, would it? I noticed that my car isn't THAT much faster all motor than it used to be...Is this due to the larger gap in the rings? I also keep killing o2 sensors at an alarming rate, but I figure that's just because it's tuned really rich for the nitrous, right? When I start slow from a stop at around 25% throttle, it feels and sounds as if it lags or misses and when I go up to about 50% throttle the exhaust note shifts and the car kinda leaps. And no the leap and the change of sound isn't from the increase throttle, it's totally different. Lastly, I noticed that around 6k rpm and above, my lights dim. I recently replaced my alternator with a high output so I'm pretty sure its not that. Anybody else have this problem?
Any help/suggestions/opinions are greatly appreciated! Thanks!!!
Did you have the car dyno tuned or just a mail order? If its a mail order get the car to a tuner and let them do their thing. Your car should not be running that rich and missing/lagging. Also running that rich can wash the oil off the cylinder walls and burn up your new rings. Off topic where do live @ 7,000ft? I'm in parkcity UT and alot of the roads around here are 6,500-7,500ft and it's a big power killer.
It was just a mail-order from TSP. But now that you say that, I'm going to get to dyno tuned next week! I live up in Santa Fe, New Mexico...It sucks doesn't it?! I read posts all day saying that their cam only cars hit 11's. **** I'm lucky to break 12's all motor lol Have you taken your blown monster to the track?
Yeah I called up Total Seal and TSP to get two opinions and they both said the same thing, so I'm hoping they're right... I'll start asking around again and if you're right I'll probably just stick with a 150 or 200 shot
1 Post
What kind of compression are you at with 59cc heads and -2cc pistons ?? How's your PTV ?? Be careful and don't miss a shift, she sounds awfully tight.
Any dyno numbers ?? Graph ?
