Trick flow 225 springs
Old 03-21-2009, 11:09 AM
10secondZ's Avatar
Default Trick flow 225 springs
I have a quick question though. I bought a set of extreme pressure patriots to put on the trick flow 225's..because everywhere I looked said "max lift .600". Upon further inspection..the spring on the trick flows are STRONGER than the patriots. My cam is a 246*/253* .632" .642" 114 and similar to an XER lobe. Would the stock trick flow springs handle this? they are 160# on the seat at 1.800 and 440# open at 1.150 I dont know the coil bind height though and cant find it anywhere
Old 03-21-2009, 05:39 PM
10secondZ's Avatar
TTT......I guess the better question is, who is running a large camshaft (over .630") with out of the box trick flow springs?
Old 03-22-2009, 07:02 AM
Kurtomac's Avatar
could you please post the information you found...I called TEA the other day...the springs are a .660 lift spring...better than the Patriot/PRC springs although made by the same spring maker (associated spring). 1.800 install height .660 max lift, bind at .720
I forgot spring pressures
was told that this was the SAME spring as the AFR upgraded 8019
Im running a XER 236 238 601 605 113+2 on my 61cc TFS heads went 127.4 NA at the track yesterday with that setup then broke my rear end on my 3rd pass
Soon swapping to a 235 243 621 624 111+3 LSL lobed PatG spec'd cam
BTW didnt I buy some heads off of you a long time ago?
Old 03-22-2009, 09:49 AM
racer7088's Avatar
Arrow
I have several times with no problems. They generally bind around 1.080 but you have to check each set as all springs can be slightly different from each other.
Old 03-22-2009, 10:52 AM
10secondZ's Avatar
I got the specs straight from the head sheet. 160@1.800 and 440@1.150 431 per inch rate max lift .650" is what the sheet said. I'm gunna take the Patriot xtremes off and put these back on. Anyone need a brand new set of extreme .660"s lol. Yeah I think I sold you my 5.3 TEA's right?
Old 03-22-2009, 10:53 AM
10secondZ's Avatar
Erik,
Awesome man, thanks! Thats exactly what I needed to hear
