MS4 Cam Card / Spring Pressures
Old 03-21-2009, 06:55 PM
Meen95z's Avatar
Question MS4 Cam Card / Spring Pressures
Does anyone have a cam card for the ms4 cam? I bought a set of Texas Speed ls6 heads, stage 2.5 and they have prc valve springs on them, just want to make sure I have the right spring pressures for the ms4 came. Any info would help greatly.. Thanks
Old 03-21-2009, 09:29 PM
SS4Luck's Avatar
if they are the duals that are rated to .660" lift i dont see why they wouldnt be? i know there are alot of people running around with stg1 heads and an MS4
Old 03-21-2009, 10:03 PM
massconfusion's Avatar
here goes- adv dur int-289 exh-291 duration@.05 int 239 exh 242
max lift: int .651 exh .608 and whatever your lobe sep angle is. mine is 112
hope that helps
Old 03-22-2009, 02:05 AM
Meen95z's Avatar
yea, they are prc dual springs, rated to .700 lift I think. Just wanted to check the pressure to make sure its enough.
Old 03-22-2009, 02:56 PM
melroy293's Avatar
https://ls1tech.com/forums/generatio...cam-guide.html
Old 03-22-2009, 04:01 PM
slothy's Avatar
Quick Reply: MS4 Cam Card / Spring Pressures
