TFS 215's vs LS6 "243" Stock
Old 03-23-2009, 07:07 PM
MAXXLIMIT's Avatar
Default TFS 215's vs LS6 "243" Stock
What is typical horsepower difference between stock LS6 "243" and TFS 215 on a stock bottom end LS6 with a MS4 cam.
I want to hit 500rwhp with:
TFS 215's
ASP Underdrive Pulley
92mm FAST Intake
LT's (heat wrapped)
MS4 Cam
90mm T/B
Tuned
Varam Intake System
MSD Ignition Wires
Coolant Bypass
Do you guys think that this little power package will get near there?
Old 03-23-2009, 07:57 PM
9secondsflat's Avatar
sorry you wont get there with that combo....maybe 450-470 tops even with the tfs...add a meziere and you can add another 6-8 rwhp...
Old 03-23-2009, 08:12 PM
CUR 4 VNM's Avatar
you should be around 440-460 with the ls6's and maybe 470-480 with the tfs. looks like a good combo
Old 03-23-2009, 08:14 PM
Shawn @ VA Speed's Avatar
i think you could do a little better with a different cam,your headers and exhaust will affect the hp as well.
i got one coming into the shop next week-we are trying to hit 500 with the tfs 215's and stock bottom end-my cam choice was much different-if you wait a week of 2 i can give you the results.
Old 03-23-2009, 08:17 PM
edcmat-l1's Avatar
I hit 482 with a similar combo, my cam, through a dual disc clutch and 12 bolt 4.10. Using the TFS 215s.
We should get the one Shawn's talkin about pretty close to 500 rwhp.
Old 03-23-2009, 08:42 PM
MAXXLIMIT's Avatar
Yeah hit me back with the results.
I have done 430rwhp and 400rwtq
with only:
MTI X1 cam
LT's
custom exhaust
Varam Intake
coolant bypass
thats it. The stuff on the 1st post is what i am going to have done.
Old 03-23-2009, 09:14 PM
Nitroused383's Avatar
with only:
MTI X1 cam
LT's
custom exhaust
Varam Intake
coolant bypass
430 rwhp with a cam only X1 cam? Sounds like a pretty generous dyno, what kind of times did you run? I think you could do 500rwhp on that same dyno with the setup you are talking about. Look into a custom speced cam over the ms4, there is a bit to be gained.
Old 03-23-2009, 09:34 PM
MAXXLIMIT's Avatar
DynoJet
Old 03-27-2009, 06:10 PM
MAXXLIMIT's Avatar
so what is typical hp gains with tfs 215 over stock 243's?
Old 03-28-2009, 12:03 AM
kmracer's Avatar
you kinda gotta do your reseach man. you should compare flow specs, and do alot of dyno and track number seaching.
i'll put it this way, theres quite a few guys over 500 with tfs heads, and not many with the ls6's. for sure none with stock ls6's.
