My 2009 Combo Chime in With Opinions/Suggestions
Old 03-24-2009, 12:07 AM
2002CamaroSS1982's Avatar
Default My 2009 Combo Chime in With Opinions/Suggestions
Hey all, have tentatively put my 2009 combo together, the car is a 2002 M6 Camaro SS with 11k miles. Below are the parts, please feel free to chime in with any suggestions.
Hooker 1 3/4 COMP Headers Ceramic Coated
Hooker O/R Y Pipe
DMH Electric Cut Out
Livernois Stage 3 LS6 Castings
TSP MS3 Cam
Comp Pushrods
SLP U/D Pulley
SLP High Volume Oil Pump
JP Double Roller Timing Chain
Cometic Head Gaskets
ARP Head Studs
ARP Head Bolts
42# Injectors
Walbro 255lph in tank fuel pump
Possibly FAST 92mm Intake with 92mm Nick Williams t/b
SLP 85mm Z06 MAF
Textralia OZ700 Clutch/Flywheel package
MSD Wires
Nitrous Outlet 78 or 92mm plate kit
NANO Nitrous 10# kit
Nitrous Outlet Purge Kit
Switch Panel
Nitrous Outlet Window Switch
Adjustable fuel pressure regulator
Fuel pressure safety switch
100 or 150 jets
I know I know, the 10 bolt isnt going to last and I definitely will need suspension but tell me what you think for now!
Thanks!
Old 03-24-2009, 09:08 AM
conan's Avatar
Sounds good, I would go for the the arp head studs. Gaskets I would go with a GM mls head gasket. My cometics have been great but they are picky about how smooth the block deck and and heads are. One more thing for the list sub frame conectors, lca's, panhard rod, and torque arm.
