what oil pump to use?
Old 03-27-2009, 12:14 PM
nobird8991's Avatar
Default what oil pump to use?
doing a lq4 swap? what oil pump should i use for it? would the ls2 oil pump be ideal or what one is best for it?
Old 03-27-2009, 12:17 PM
witry's Avatar
go with a melling 10295 or 10296.... 10296 is higher volume with higher pressure spring...10295 is stock volume but higher pressure spring
Old 03-27-2009, 02:26 PM
nobird8991's Avatar
so if i'm running a 6.0 with a ls1 oil pan should i just run the 10295?
Old 03-27-2009, 02:54 PM
witry's Avatar
yeah you can it will work
Old 03-27-2009, 02:56 PM
nobird8991's Avatar
alright cool. where would be the best place to get one?
Old 03-27-2009, 03:38 PM
Raptor_WS6's Avatar
i am using the 10296,
Old 03-27-2009, 04:23 PM
witry's Avatar
http://www.speedinc.com/catagory.cfm...in%20/%20Heads
go about half way down you will see it thats the best price i found
Old 03-27-2009, 05:23 PM
Chris10an's Avatar
Thumbs up
SLP here...
http://store.summitracing.com/partde...5&autoview=sku
Old 03-28-2009, 12:37 AM
SIKSIX's Avatar
Lingenfelter has the best price on 10296 for only 129.95
