PAC 1518 or AFR 8019 Spring
Old 03-28-2009, 05:44 AM
SkylarkLS1's Avatar
Default PAC 1518 or AFR 8019 Spring
I need to step up on springs wondering what you guys recommend with AFR 205s. 1518 Nitrided Beehives or the AFR upgrade. Thanks
Old 03-28-2009, 07:14 AM
eamador11's Avatar
depends on the specs of you cam.
Old 03-28-2009, 12:45 PM
vettenuts's Avatar
What springs do you have now? If you have the AFR standard spring, the 8019's drop right in with the same seat/retainer.
Old 03-28-2009, 06:47 PM
SkylarkLS1's Avatar
I heard the pac are also drop in units...I have a custom grind cam, I will post up the specs on it, once I get them from my buddy..
Old 03-28-2009, 06:53 PM
vettenuts's Avatar
The PAC 1518's are beehives. The original AFR's are duals. If the heads you have now have AFR springs (duals) then the PAC's are not drop in. They will require different seats and retainers.
Quick Reply: PAC 1518 or AFR 8019 Spring
