Help-tr224-Help
Help-tr224-Help
Trying to install new cam using the rod method. Got 5/16 rods and they are not holding up the lifters? Lifters wont come up high enough to get the rods underneath. Spinning cam and using pencil magnets! just cant get them high enough!! Help please
LSX Mechanic
I've used the rods a million times.
It's unlikely, but possible a lifter(s) got turned and now won't go up into the retainer. Or the retainers are just slap wore out. When you say they "wont go in", are you saying when you're pushing it comes to a dead stop? Or is it just tight? It's always going to be tighter on the pass side than the driver's side. It also helps if you round off the tip of the rods with a grinder wheel, and lube them up with a little bit of motor oil.
Whatever you do, don't pull out the cam until those two rods are bottomed out at the back of the motor.
retr224
the car has a lot of miles but runs good. the retainers are most likly worn. i have tried pen mag. but i can`t get the lifter up high enough to get the rod under it. i have put a point on the rods and oiled them with no luck
tr224
from my experiance grind a small flat down one side of the 5/16 rod, oil rod and it will go in. lifters will still go by if you force them. the rod lays beside the lifter not under them. they are made withplastic cagesto keep them from falling down. the rods are just extra precaution.
