TR220 guys inside
Old 10-22-2003, 08:40 PM
Red01Chevy's Avatar
Default TR220 guys inside
what do you guys think about TR220 cam
how would this cam work on a stock convereter
would it run ok without tuning
wt are yall shift points set at
12.85@107 1.90 60'
Old 10-23-2003, 08:46 AM
Paul F's Avatar
Default Re: TR220 guys inside
Some A4 cars do require tuning for the idle. I would recommend a converter for almost any aftermarket cam for best performance. I would shift the car about 6400 rpms.
Old 10-23-2003, 11:44 AM
KF2KZ's Avatar
I run this cam with the stock converter. I felt the stock idle was a bit low for the cam, there was a bit of hunting, but not much at all once the car was warm. Tuning has helped out tremendously, raised the idle to around ~800 or so, no hunting, no stalling, no surging. Shift points are ~6200 with a 6400 cutoff, my trannys getting a bit weaker with over 60K miles on it, so I stayed on the safe side. Good luck if you choose it!!!
