Help!! Cam advise?? Head advise???
Old 04-01-2009, 12:53 PM
FBODYFEVA's Avatar
Default Help!! Cam advise?? Head advise???
I have a 2002 camaro ss m6 all stock....i have a set of 243 heads in my shop but i am clueless on what cam to use...i've heard 2002-2006 vette z06 cam is perfect but i wanna do some checkin around first and would anyone recommend using the 243's or jus sellin them an buyin some good cnc's
??????any help is greatly appreciated
Old 04-01-2009, 01:06 PM
fast's Avatar
goals?
search should give you a lot of threads to read
too many options and opinions in the lsx world ... it all starts with you being honest about what you want your car to do and what it'll be used for
Old 04-01-2009, 02:08 PM
FBODYFEVA's Avatar
I will drive the car everyday to and from work weekend streetracing and occasional track time
honest enough for ya?
Old 04-01-2009, 11:07 PM
yellowjacketfever's Avatar
first off do not sell the 243's. they work very well on the ls1 engines. as far as a cam i love mine. excellent cam for a low all the way to 7000 rpm range. if i had a better bottom end i could go even higher rpm with this cam. as it was a steady climb makeing hp all the way to 6900 rpm.
Old 04-02-2009, 11:53 AM
FBODYFEVA's Avatar
preciate it yellowjacket
Old 04-02-2009, 03:11 PM
00firehawk's Avatar
I am running 243 heads on my stock ls1 bottom end. I had my heads bolw blended and back cut valves which woke them up tremendously. I am running a tr raptor cam with a ls6 intake. My cam is rather larger but i still use it for everyday driving, and street racing. My mpg isn't bad either, and with that cam i make power to 6800rpm.
The only problem i ran into with my set up is my motor need more air and more fuel so i have to upgrade to get the most out of it but as it sits now it pulls like a ***** and extremely fun to drive. If you need any more info on anything just pm me
Old 04-02-2009, 03:19 PM
FBODYFEVA's Avatar
OK probably goin with the 228r cam and the 243 heads with 918 springs should push over 400 with tune
Old 04-02-2009, 03:21 PM
00firehawk's Avatar
Sounds like a good set up..... I have a 236/242 cam and makeing 420rwhp and i have alot of growing room
Old 04-02-2009, 03:25 PM
FBODYFEVA's Avatar
ah yeah i've only got ls6 intake smooth bellow and trying to find the 228r now...already have the heads and springs are on the way....should be a nice setup...prolli gettin tuned at premeir autosports
Old 04-02-2009, 03:27 PM
00firehawk's Avatar
Keep me posted...... I highly advise doing that head work i mentioned. That same head work on my 243 cost around $300. It a night and day diffrence!!
Old 04-02-2009, 03:28 PM
00firehawk's Avatar
Thunder racing also has some great custom grind cams and cam packages and not badly priced either
Old 04-03-2009, 07:45 AM
FBODYFEVA's Avatar
yeah...i think i'm gonna do as much as i can to the 243's then go with the 228r cam/918 springs, lock retainers, and maybe a lil bit of happy juice...
