patriot vs. afr heads
Im looking at getting either patriot or afr heads. I know that patriot heads are a lot less than afr heads price wise. Now what is the difference in HP?!?
It is like comparing a donkey to a horse. AFRs are pure thoroughbreds. It is not only a matter of power, but efficiency, throttle response, torque, and quality. AFR 205s are one of the best aftermarket grinds to date for street use.
What are your goals and list of mods, cam etc...
my .02 just get the tfs 215's from ron at vengeance...have them milled to put you in the mid 11-1 c/r and call it a day...power from 2k-7k.
Bang for the buck i.e. $ per horsepower, Patriot is hard to beat, but when you've done everything else and you're looking for that last 20 horsepower, you might wish you had spent the extra money. You could always try buying a clean set of used Patriots and try them out. If you don't get where you want with them, you can sell them for a small loss if any and step up to the TFS or AFR's
Best budget head is Patriot and PRC. They produce amazing flow and actually outflow the afr in most spots .
Patriot =
https://www.patriot-performance.com/...&cat=37&page=1
AFR =
http://www.airflowresearch.com/store...e637695bdff47f
Patriot =
AFR =
although some of the other heads may outflow the afr's,they dont have the cross section or port volume as small as the afr's.The end result -the afr's will always make more power over the patriot/prc.Not only that but throttle response and midrange torque from the afr's is better.like the other guys have said,if the extra 15-20hp is worth the extra money,is up to you
Patriot =
AFR =
Patriot =
AFR =
No comparison between the two. AFRs will make more power across the board, better throttle response, better efficiency (less spark advance needed), etc...
Although, I also like the ETP215 heads.
The PRC215 is an aftermarket casting. The cost is nowhere near the Patriot's. The PRC215 is competition to the AFR, TFS heads; it's not a budget head. PRC does offer lower cost ported stock GM castings. IMO, PRC will offer the best quality and power per dollar. No matter what your budget, high or low, PRC has a product that will work best for you.
LS1Tech Sponsor
GTP241S1 Stock ported 241s come with stainless valves and LS6 springs.
http://www.sdparts.com/product/GTP24...nderHeads.aspx
in texas as well, but the only extra for you is tax, still free shipping
im also in the same boat. ill looking at doing heads here shortly. i know the AFR are one of the best if not the best. but ive seen some great #'s lately with those patriot heads. i think speed inc did a H/C car with patriots that put down 45x range i think... i mean its tough to beat 1200 bucks shipped assembled with double valve springs.
