Cam sensor is broke from rubbing on crank! wtf
Old 04-04-2009, 08:29 PM
Pheonix's Avatar
Default Cam sensor is broke from rubbing on crank! wtf
Does any one know why my cam sensor behind the intake was rubbing on my reluctor wheel on my crank? I took it out to tighten a new oil sending unit i broke while pulling the motor and found out that it was broken from the very bottom. My motor had some knock and i believe it was coming from that now that i see the damage fromt the sensor. What can cause this?
Tried search, but we all know how that POS is.
Thanks, Pheonix
Old 04-04-2009, 11:00 PM
Steve Gunn's Avatar
WTF? Never heard of this, but I just put mine in a few minutes ago and now I'm trippin'... thanks!
Old 04-04-2009, 11:09 PM
Pheonix's Avatar
lol how does the cam sensor work? Does it read off the cam or the crank reluctor wheel? Is it possible to brake it while changing cams, or replacing cam bearings?
I had my cam bearings replaced and i know that takes some yanking.
Old 04-04-2009, 11:20 PM
conan's Avatar
Its not possible for the reluctor to hit the cam sensor. It could have got damaged changing the bearings. The crank sensor picks up on the cam. A crank position sensor picks up on the reluctor wheel.
Old 04-05-2009, 12:02 AM
Pheonix's Avatar
Ok, cool man. I looked closer at the sensor and the scar marks are from back to front. So that means it had to be from yanking on the bearings.
Thanks
Quick Reply: Cam sensor is broke from rubbing on crank! wtf
