2002 Zo6 PVC system
Old 10-24-2003, 01:28 PM
gee65's Avatar
Default 2002 Zo6 PVC system
what is different on a 2002 ZO6 Corvette's PVC system that keeps the intake oil free!! I want to change my 2001 TransAm over to the Vettes system so I don't always have oil in the intake. What do I need???
Old 10-24-2003, 01:35 PM
Smitty's Avatar
I've done it to my car back before the cars came out,but the parts were available.I must say it was a waste of time,did'nt make any difference.It still gets oil in the inatke.There is a write on the parts install on www.ls1howto.com
Old 10-24-2003, 02:05 PM
LAST ONE's Avatar
The Corvette system pulls the vapors from under the intake manifold while the F-bodies pull the vapors from the back of both valve covers.Both systyems seem to be ineffective so the best solution is to use a catch can or air water seperator between the pcv valve and the throttle body.The only down side is that it has to be emptied periodically.
Old 10-24-2003, 11:00 PM
INMY01TA's Avatar
I did the conversion and it was a total waste of time and several hundred $'s. Save your money and get a catch can.
Old 10-25-2003, 12:29 AM
2001CamaroGuy's Avatar
I did it. While it did seem to cut down on the amount of oil getting in the intake, it did not prevent it compleatly (still get a thick "film" of oil in there). I need to make a catch can to improve the system but just have not done it yet.
Old 10-25-2003, 03:06 PM
felton316's Avatar
Damn, I did mine when I put my LS6 intake on, then I removed the intake 700miles later to paint it and it was totally dry and clean on the inside. I do have a 98 Camaro, if that matters. I thought it was a great mod, and I was able to do it for about $45.
