fuel pump wiring
Old 04-06-2009, 04:19 PM
1fastmofo's Avatar
Default fuel pump wiring
my relay is clicking but nothing from the pump, car was flipped, can someone tell me the easiest way to wire the pump direct before i drop the tank???
Old 04-06-2009, 05:59 PM
1fastmofo's Avatar
no one?
Old 04-06-2009, 07:32 PM
1fastmofo's Avatar
do they happen to have an inertia switch like a ford does?
Old 04-07-2009, 06:29 PM
1fastmofo's Avatar
afternoon bump
Old 04-07-2009, 08:12 PM
Pocket's Avatar
Need to know what harness you have to say for sure, but this should get you started
This is the fuel pump relay for a 3rd gen f-body
Ignoring the majority of it, you see there's basically a 12V in and a 12V out to the fuel pump albeit mislabeled in the diagram (Relay failure not ECM)
Remove the relay and jumper the terminals; not being a 3rd gen the pins will not be the same, but the colors/functions should be if you are using a GM harness
Alternately you can use the test lead if your harness is equipped and you can locate it
Old 04-08-2009, 12:03 AM
1fastmofo's Avatar
sorry the car is a 2001 ws6 trans am. I was wondering why i was not getting a reply....if my relay is clicking... I must be loosing power after? Or would that mean that it is dead at the tank?
Old 04-08-2009, 12:04 AM
1fastmofo's Avatar
the r9 dark green wire where does it go?
Old 04-08-2009, 12:11 AM
dub.ya.es.SICK's Avatar
hmm clicking relay... id jump the relay and see if ur pump works...relays are sweet but can suck, id drop ur tank and fix your problem
Old 04-08-2009, 06:31 PM
1fastmofo's Avatar
yea i will likely have to drop it just wanted to see if i could isolate and make sure I have to drop it....I hate dropping tanks
Old 04-13-2009, 06:51 PM
Pocket's Avatar
R9 is the pin placement at the PCM
Red 9
Click means the relay is energized, your pump should engage. No sound = bad pump
Old 04-19-2009, 10:21 PM
1fastmofo's Avatar
so if 9 gets hot on key up something wrong in the tank...if not hot then just energize 9?
Old 04-21-2009, 11:37 AM
1fastmofo's Avatar
car took a hard hit thinking something may have been jared in the wrecked near the comp as to that was the area with the majority of the damage
Quick Reply: fuel pump wiring
