Broken header bolt-broken easy out-I'm fugged!
Old 04-06-2009, 09:00 PM
Steve Gunn's Avatar
Default Broken header bolt-broken easy out-I'm fugged!
I was getting ready to drop in my motor and noticed the machinist neglected to remove a broken header bolt from the head. No big deal, right? Just drill it out and use an easy out. Broke the damn easy out and now I'm destroying bits because the easy out chunk is too hard to drill into. There is not enough bolt to do the "weld the nut on trick" Any advice or is the motor going to the machine shop?
Thanks!
Old 04-06-2009, 09:07 PM
98RedBird's Avatar
Thanks!
At the point you're at I'd just take it to the machine shop. I always say it when a situation like this arises, but if you're not confident that you can remove it yourself then just pay a little to have it done. If you **** it up you're fucked... If they **** it up then it's on them...
Old 04-06-2009, 09:15 PM
PongoX11's Avatar
...and when they tell you the threads are damaged, I have a very nice Kentmore timesert kit for sale
Old 04-06-2009, 09:31 PM
Steve Gunn's Avatar
Thanks, Redbird. Makes sense.
What's that? Beside being just slightly ghetto, what's wrong with a helicoil?
Old 04-06-2009, 09:33 PM
Steve Gunn's Avatar
Just googled it... holy crap! $400.00????
Old 04-06-2009, 10:53 PM
hitempguy's Avatar
my .020(.02 CAD = 0.0160795 USD) These are from my post on another site....
Yeeha, got the little buggers out. Here are some pics, the ones of the broken bolts before I started didn't turn out. Sprayed the head with spatter release, then cleaned the broken stud. Welded a bead on the stud and built it out, then welded on the nut. would protect the head more if you could hold a washer against the head. Took about 2 hours.
__________________
94 Z28, M6, CAI
96 Z28 M6 - Sold
1990 Turbo Firefly (16lbs. boost, 109 octane, you should have seen the look on the MazdaSpeed6 dudes' face)
Attached Thumbnails Broken header bolt-broken easy out-I'm fugged!-camaro-20broken-20exhaust-20manifold-20bolts-20034.jpg   Broken header bolt-broken easy out-I'm fugged!-camaro-20broken-20exhaust-20manifold-20bolts-20030.jpg   Broken header bolt-broken easy out-I'm fugged!-camaro-20broken-20exhaust-20manifold-20bolts-20029.jpg   Broken header bolt-broken easy out-I'm fugged!-camaro-20broken-20exhaust-20manifold-20bolts-20032.jpg   Broken header bolt-broken easy out-I'm fugged!-camaro-20broken-20exhaust-20manifold-20bolts-20047.jpg
Old 04-06-2009, 11:21 PM
ramair21's Avatar
great idea! Glad you got it out man.
Old 04-06-2009, 11:52 PM
dub.ya.es.SICK's Avatar
molson canadian sounds tasty right about now
Quick Reply: Broken header bolt-broken easy out-I'm fugged!
