Spring Swap Question
I'm in the middle of a cam install and trying to change the valve springs. I bought the adapter to pressurize the cylinder along with the Crane spring compressor. The problem I'm having is that I am losing air pressure slowly to begin with and as soon as the compressor starts, I lose all my air. and it sounds like I have blow-by going into the oil pan. Do I need a compressor with more volume? Should the piston be up or down? I have it at TDC in case the air fails so I won't lose the valve and the pressure regulator set at 70 psi but I'm paranoid about screwing something up. Any suggestions????
The rope method is when you put the end of a rope into the cylinder via the spark plug hole, then bring the piston to TDC and youll feel it pinch the rope between the piston and valves. This worked great for me, you can do 2 cylinders at the same time. I think I used a 5/16 rope (Just make sure its not all falling apart/dirty).
thanks for the info.
If the piston is at TDC then the valves will stay up high enough to swap the springs? I guess I will pick up some rope just in case the air tool isn't cutting it.
