ls1+afr 205+gt11=290wrhp ..!!!
I have a problem engine
stock ls1 347ci block with
5.3l heads porting 59cc
cam 207 220 571 581 118 lsa
rocker arm 1.7
seytem EXHAUST 2.5"
HEADERS 3"
SLP Premium balancer
42lb Injectors
FAST INTAKE MANIFOLD& 92MM THROTTLE BODY 92MM
Lingenfelter COLD AIR INTAKE
give me 309wrhp
then
change the heads with afr 205 66cc
GT11
pushrod 7.400
slp oil pump
give me less than 300 wrhp
i have also problem from long time low oil Pressure Even with 2nd setup
Will check tomorrow engine Mechanically and electrically
and check Cylinder compression first
any Advice I would be happy
rocker arm 1.7
seytem EXHAUST 2.5"
HEADERS 3"
42lb Injectors
give me 309wrhp
then
GT11
pushrod 7.400
slp oil pump
Moderator
You had something wrong before the Heads & cam swap. A4 or M6 tranny?
Could be compression problem?
Could be pushrod length?
Could be a slipping clutch?
Could be a bad tranny?
Who tunned the car & what do they think?
i will check slipping clutch also
thanks davered00ss
2nd heads afr 205 66cc
difference Even low copression , but AFR heads must give me more power
At least above 400
thanks elias
Yeah thats a small cam which means a high dynamic compression ratio. Are you sure the cam is installed correctly too? Not off by a tooth. You should have been making 309rwhp without the cam or the heads really.
As mentioned compression check the motor, pull the timing cover and check the cam maybe. When you had the heads off did you look at your lifters or anything? What length pushrods did you measure for with how much preload?
After checking the engine electronically indicate that there was a malfunction
knock and map sensor not working so changed
nothing change
Still i will check Compression Pressure for cylinders Tomorrow one by one
pushrod changed form stock to 7.400 with 2nd setup
timing lifters Normal after setup
low oil pressure show Warning Come and go !!!
I think the problem from the block now after overhaul befor the 1st setup
thanks
nothing change
thanks
