does arp make rocker bolts?
Moderator
You should be able to find something at the hardware store, if you're in a pinch. I think the threads are M8x1.25 and for the rockers, I think 35mm length will do. If the threads in the head are jacked up, you may need to helicoil it, which I don't know if you should do by hand.
No ARP does not make rocker bolts for the LS1 unfortunately. I spent sometime on the phone with them not to long ago trying to see if they did and they couldn't even get me something close. They wanted me to send them a rocker bolt and they could make me a custom set but that was gonna cost way to much so i just bought new GM ones.
