What do you think??
Old 04-12-2009, 02:55 PM
zz28Junior's Avatar
Default What do you think??
I have a 2000 z28 camaro and all i have is TSP 1 7/8 headers the Y pipe and a SLP catbac and nitrous and i want a H/C kit....and i want to get the trick flow kit that summitracing has heres the link http://store.summitracing.com/partde...w=1&N=700+150+
let me know what you think??
Old 04-12-2009, 03:06 PM
blk/slvr02ss's Avatar
That kit is not bad but if you look @ Texas Speed's web site you have more to choose from and i would also go w/ a LS-6 intake if you don't already have one.
Old 04-12-2009, 04:55 PM
zz28Junior's Avatar
I like that kit over most of the Texas speed kits
Old 04-12-2009, 05:40 PM
Zach79Z's Avatar
Yes the kit is nice but i beleive the texas speed kits are alot cheaper. correct me if im wrong
Old 04-12-2009, 06:30 PM
zz28Junior's Avatar
so yall think its worth the money or even getting it
Old 04-12-2009, 06:31 PM
Zach79Z's Avatar
I havnt heard much about trickflows kits. I know they make good heads so im sure the kit is good were just tryin to save you some money
Old 04-12-2009, 06:41 PM
zz28Junior's Avatar
oh ok thanks...which kit from texas speed would you get that matches up with this one from trick flow?
Old 04-12-2009, 06:42 PM
Zach79Z's Avatar
what texas speed cam do you like? Personally if i was guna get a heads and cam kit from there id go ms3 with 2.5 5.3l heads
Old 04-12-2009, 06:45 PM
zz28Junior's Avatar
do you think that one equals out to the kit from trick flow? do u think it would give me the same numbers as the kit from trick flow??
Old 04-12-2009, 06:46 PM
Zach79Z's Avatar
If your lookin for about the same power go with 2.5 ls6 heads and tsunami cam. Made 463rwhp
Heres a link to the thread
https://ls1tech.com/forums/dynamomet...o-results.html
Old 04-12-2009, 06:51 PM
zz28Junior's Avatar
do you think does heades and the cam would be good if i want my car to be a 10 second car?
Old 04-12-2009, 06:54 PM
Zach79Z's Avatar
Yeah i think its doable with that setup. Id call texas speed and see what they think about it tho. Plus with the money you can save (you can get a kit for around $2000 with oil pump and such) you can spend the rest on the rearend or suspension to help out.
Old 04-12-2009, 06:56 PM
zz28Junior's Avatar
yeah great idea thanks bro
Old 04-12-2009, 07:01 PM
Zach79Z's Avatar
No problem just tryin to save you some money
