LS1 Heads .vs LS6 Heads
8 Sec Tuner
How much more RWHP are LS6 heads worth over LS1 Heads? Assuming you had simular port work done to both and the same valves and valve job?
I.E My Car made 455 RWHP with Stg 2 LS1 heads with 2.02 1.60 valves the heads flowed 305 @ .600 lift on the intake and 227 @ .600 on the exhaust.
Now the bolt on LS6 heads that would flow more CFM's how muh RWHP is it worth?
Im trying to justify the cost of some new LS6 heads over some used stock LS1's.
