Torturing a 5.3L got ideas?
Old 04-14-2009, 04:59 PM
Platinum 2k9's Avatar
Default Torturing a 5.3L got ideas?
Like the title says, I'm going to be torturing a 5.3L. Ya know make it cry for mommy. So let me hear some ideas and remember I'm creative. I can junkyard build all sorts of stuff. This is all on the STOCK rods,pistons,crank.( if I kill it no biggie, gives the excuse for the 6.0L) Think I can get close to 500 RWHP before it blows?
Idea #1: 200 wet shot, different cam,LS1 intake,LS6 injectors and rails.
Idea #2: remote mount twin turbo kit, 15-20 psi.(tuned for E85)
Idea #3:??????
For heads/cam ideas let me know what you have in mind.The LS1 intake is just for the 5.3L. The F.A.S.T 102MM is later on down the road for the next motor.
Before anyone flames me, I'm getting the motor dirt cheap and don't really care if I kill it. the 5.3 is going in to complete the swap. Ultimate plans call for a forged 6.0L later on down the road.
Old 04-14-2009, 05:04 PM
nastychevelle's Avatar
im doing a 5.3 for a 200 wet shot right now....
with studded heads and arp rod bolts on a good tune a 200 shot should be fine...
if your gonna torture it do something like this
stud the heads
ARP rod bolts
big cam ?(something that likes nitrous) (like ms4)
ls1 intake with P&P TB
do a progressive wet 250 shot i bet you could pull of 600hp with ported stock heads or 243 heads
Old 04-14-2009, 05:09 PM
JohnFrazee02SS's Avatar
how about idea 1 and 2?
Old 04-14-2009, 05:15 PM
Ice78Transam's Avatar
Ouch. Just remember to always have a camera on when the car is on. That way, we can all laugh.
Old 04-14-2009, 05:36 PM
jmilz28's Avatar
ARP studs and rod bolts + LS6 cam + BIIIIIIIIIIIIIG turbo(s). Maybe even strap on the 6.0 heads and REALLY crank the boost. This sounds like fun!! Make sure you give it enough fuel and I bet you make 600 at the wheels for while too.
Old 04-14-2009, 07:04 PM
I give it a week to live if I pair up ideas #1 and #2!
Studs are already in the works for both motors. I just want to push the little 5.3 to its limits.I wonder if I could get my girl into the 10's on that 200 shot with a big cam and not caring about the motor?
For the spray it will be a progressive shot to preserve my drivetrain. If I kill my rear end then I'll cry!
For FI I'm thinking about a pair of T76's and make the boost higher up in the RPM range. When the boost comes on she'll pull like a freight train.
I'm mainly using the 5.3 as a test of sorts. Its the test bed for everything that will come on the 6.0. I.E the tuning, the boost, the spray.( 6.0L is getting boost and a 75 shot to help get the turbo's spinning quicker).
Old 04-14-2009, 07:35 PM
if you pair 1 and 2 you could go 9's but no one has really ever pushed them as far as nitrous goes so why not do something like a 250 shot progressively
and if you go boost why not try out the new edelbrock intake? its supposed to be good for Fi and has long runners so you can do direct port higher up in the runner to get good atomization
Old 04-15-2009, 03:17 PM
dre2013's Avatar
this actually sounds like a good idea..ive been wanting to do something like this (test the limits of a cheap stock block) but i dont have the resources...my ls1 will be my test-pig lol
Old 04-15-2009, 04:20 PM
5.3L's are going for between 275 and 600 from the junkyards. thats 2 tires on the low side.( or just one for me-315/35/17's)
I'm paying 300 for my 5.3L thats why i'm using it as a test bed for everything.
Once the swap is complete its only a day to R&R the motor.
I want to make sure everything is absolutely perfect for the 6.0 once it goes in. If I kill that one then I'll be upset and my other half will kill me! she's ok with me destroying a 300.00 motor but definitely not a forged one.
Old 04-15-2009, 04:41 PM
studded heads and ARP rod bolts
MS4 on 112lsa
progressive 250 shot maybe go 275 if you really want to push it
thats my vote cause like i said so many people have pushed the stock bottom ends as far as boost but no one really has pushed it as far as nitrous goes i wantto see what these things can handle as far as spray goes
Old 04-15-2009, 05:56 PM
kmracer's Avatar
the ms3 is a better nitrous cam, but either is a midge too big for the 5.3. something along the lines of a torquer, or a simmilarly sized cam would be alot better for a 5.3.
Old 04-15-2009, 06:03 PM
nitr0racing21's Avatar
Idea 2!
Old 04-15-2009, 06:10 PM
ss454327's Avatar
I wouldn't buy any parts that I wanted to keep for the 6.0 because you're likely to grenade this thing and ruin any heads/cam/turbo upgrades you do. I'd do a 200 wet shot after upgrading all the bolts to ARP studs and see how long it holds up. I bet it would hold up fine for longer than you think.
Old 04-15-2009, 09:17 PM
MasterMindMotorsport's Avatar
what happens if you use a ls1 crank and rods in a 5.3, will that equate to a 5.7 ?
ive seen iron block 5.3 guys with 5.7 liters in their signatures ect.
Old 04-16-2009, 09:06 AM
the stroke is the same but the bore is different. from what I've read( don't know for a fact though) you "could" bore it out to a 6.0.
Old 04-16-2009, 10:38 AM
2002_Z28_Six_Speed's Avatar
I think so, too. I have a 5,3 and I want more out of it but I have no idea what to do with it. It has the Z06 cam in there now. But, not enough.
Someone also stated to use 6,0 heads. How would that help if they are designed for a different bore size? Would it help? I am thinking it might lower compression and cause other issues. Just asking.
Old 04-16-2009, 04:25 PM
many people have been using 317's on there for a while and i haven't heard of any problems
Old 04-19-2009, 11:52 AM
awww since you are kind of aware of the trues and falses of this situation do you know the approx gains or any additional information?
Old 04-19-2009, 12:01 PM
ramdaspadhye's Avatar
Are any 5.3 heads aluminum?? I have some 317 heads I would trade for some 5.3 heads
Old 04-19-2009, 01:50 PM
Mine are. I have a 2004 or 2003 SSR motor. 5,3 all AL. It isn't slow but it isn't fast enough. I can't tell the diff between driving it and a stock f body.
