Predator Z-cam question with a vig 3200
Old 04-14-2009, 07:17 PM
seadoo's Avatar
Default Predator Z-cam question with a vig 3200
is the FMS F5 224"/228" .588"/.576" cam a good match with a vig 3200. It should make the torque in the lower end like the TR224 yet carry a bit more peak power as well correct?
referring to this graph...
Old 04-14-2009, 08:16 PM
PREDATOR-Z's Avatar
Not necessarily, put theoreticaly by having a tad more overlap yes. However they have 2 different lobe profiles, they would be very close to each other on the same LSA/ICL, TR224 will make a tad more cylinder pressure.
Old 04-14-2009, 08:20 PM
seadoo's Avatar
really, or cylinder pressure with the TR224 with .563? going a bit technical, but can you explain why?
Old 04-14-2009, 09:08 PM
seadoo's Avatar
so what would you recommend? vig 3200, stock LS1 intake for now, headers/ory/magnaflow cb.
Old 04-15-2009, 06:27 AM
PREDATOR-Z's Avatar
Get a LS6 intake
Old 04-15-2009, 11:27 AM
seadoo's Avatar
Yeah, I know. checking around now for them. but as far as a cam. something that wont kill the springs and still make good power with the vig 3200 have tons of torque to hit the converter hard.
Old 04-15-2009, 11:58 AM
PREDATOR-Z's Avatar
230/228 .612/.588 110-1 LSA,
Custom cam, 6500 rpm, more trq than you can shake a stick at, 9* overlap (good lope).
Better get some sticky tires with that one.
If you like PM me, I'll give you the specs.
Old 04-15-2009, 06:14 PM
00pooterSS's Avatar
subscribing, have a yank 3400 stall and have the same question about hitting the converter hard down low. Im on stock long block and can only pull 1.85 60 ft's so far, boo.
Quick Reply: Predator Z-cam question with a vig 3200
