putting in forged 347 in, ok to run for short period on stock injectors?
Old 04-16-2009, 04:12 PM
2000NavyZ's Avatar
Default putting in forged 347 in, ok to run for short period on stock injectors?
putting in a forged 347 this weekend and cant get it tuned until atleast monday. I have a set of 37lb an hour injectors for it, and heard you're not supposed to run a bigger injector unless its tuned. Is it alright to run this setup of my stock injectors? its got a 232/236 cam. stage 2.5 ls6 heads, fast 90/92? my computer is tuned now for a tr 230 cam w/ ls6 intake and is running quite rich.
Old 04-16-2009, 04:22 PM
PREDATOR-Z's Avatar
yes but keep it under 4K rpm and that is for break in time only, avoid driving untill tuned.
Old 04-16-2009, 11:48 PM
2000NavyZ's Avatar
what about putting in my racetronix 37 lb hour injectorss?
Old 04-17-2009, 01:55 AM
Nitroused383's Avatar
Do not put your new injectors in until you get it tuned for them. You risk the chance of washing down a brand new engine, and never getting proper ring seal. Or even worse spinning a bearing because of too much gas in your oil. Your car will run just fine with the stock injectors just drive it normal and do not go wide open.
Old 04-17-2009, 02:17 AM
Sharpe's Avatar
Just don't drive it, dude. I mean, you can't go a few days without driving it?
Old 04-17-2009, 11:19 AM
99Ls1fever's Avatar
Even on a forged motor? What is the break in time for a new 347 Forged motor?
Old 04-17-2009, 04:50 PM
2000NavyZ's Avatar
this motor was ran by someone else for 800 miles
Old 04-17-2009, 07:41 PM
Just run it on your stock injectors for now, just dont take it over 5k rpm as you will more than likely max out the injectors.
Old 04-17-2009, 11:44 PM
goober35's Avatar
Just use the stock injectors and drive it as little as possible.
