cam suggestion for a stealth setup
who says you cant use a stock cam and get what you want? there are guys in the 10s with stock cams. Heads make or break the motor. i'd say a serious set of heads and an LS6 cam with 1.8 rockers. you can make big numbers that way. big cams only put the power band higher up anyway.
