TR224/112.....Rev limit?
Old 10-27-2003, 06:55 PM
John02SS's Avatar
Default TR224/112.....Rev limit?
I'm putting in a TR224/112 with 918's and TI retainers. What are you guys with similiar setups running as far as rev limits. My custom tune that I will be installing is 6800. Is that about right? I plan on shifting the car at 6500. Thanks for the input guys!
John
Old 10-27-2003, 06:58 PM
LS1Tech Sponsor
Slowhawk's Avatar
6800rpm is good.You can go 7000rpm if needed.
Old 10-27-2003, 07:34 PM
QwikSilver's Avatar
Default Depends doesn't it
That would depend on if his bottom end is stock wouldn't it? I didn't think it was wise to spin a stock bottom end that high.
Old 10-27-2003, 07:37 PM
BBADWS6's Avatar
If you have stock lifters you are putting a lot of stress on them taking them above 6800, but i would say you should be alright to there, but dont bang the rev limiter!
Old 10-27-2003, 07:43 PM
John02SS's Avatar
Stock bottom end. The only time it would hit the limiter is if it breaks the tires loose so fast I can't get out before it hits it. Just wanted to make sure that 6800 wasn't too high. I was originally thinking around 6700, but an extra 100 rpm isn't much.
Old 10-27-2003, 08:22 PM
BBADWS6's Avatar
Well you are taking a chance spinning it up that high, but thats part of the game.
