t&d shaft roller rocker arms
Yea, but why? HP per $ they are worthless unless you need specific valve control (ie solid roller). I don't see them picking up even 5hp compared to a harland sharp berring'd stock rocker.
The only reason to spend the money on a shaft mount rocker is if you spin the motor past 7500rpm. Otherwise there are a lot better options for the money. And you don't need to deal with aftermarket valve covers.
