2000 ws6 cam swap
Old 04-19-2009, 04:50 PM
98camZ's Avatar
Default 2000 ws6 cam swap
hey i need a little help im doin a cam swap in my 2000 ws6 6 speed and i was wondering what is all required to do a cam swap, i know hardned push rods. I already have ls6 heads on it so the springs should be good up to 600 lift. What else do i need for sure anyone help.
Old 04-19-2009, 05:12 PM
2001ws6-500hp's Avatar
ls6 pump to be safe. timing chain.
Old 04-19-2009, 05:23 PM
98camZ's Avatar
.588 lift intake .598 lift exhaust. 228 int 234 exh duration at .050,112.0 that is the cam specs right here.
Old 04-19-2009, 08:25 PM
goober35's Avatar
What kind of springs are on the ls6 heads?
cam, push rods, oil pump, oil pump O ring, timing chain, crank bolt, motor oil, oil filter, coolant, and pen magnets or the thunderracing.com lifter holding tool.
You might need water pump gaskets, front cover gasket, and front cover O ring.
Old 04-19-2009, 08:46 PM
98camZ's Avatar
the springs that are in the ls6 heads are the yellow springs
Old 04-19-2009, 09:01 PM
transwiz's Avatar
Since you are going to be in their get ls6/melling oil pump and ls2 timing chain.I would go for better springs if it was me.(DUALS)
____________________________________
2000 t/a ws6 with lots of mods
Old 04-19-2009, 09:05 PM
eseibel67's Avatar
You will need a 4" 3-jaw puller to remove the balancer and and a tool to press it back on. You can buy the installation tool, or you can easily make one out of M16 rod and some M16 nuts and washers.
Old 04-20-2009, 01:40 AM
jetlag's Avatar
Go with at least the PAC 1218 springs
