LS1 Stock Lifter not enough for Jesel Shaft Mount 1.85s?
Just curious if I should be replacing my stock lifters to go with my Jesel Shaft Mounted 1.85 rockers?
Heads are Patriot Stage II with Patriot dual Gold Springs.
Cam is a Lunati with .596/.595 lift (calculated total lift with rockers)
Would LS7s be enough? Thanks for the help!
LS1TECH & Trucks Sponsor
I don't see any reason that you would need to replace the lifters. The only time you would need to worry about them not being stout enough is if you went to a monster valve spring with a massive open pressure.
