i want 440 rwhp
Old 04-22-2009, 12:25 PM
ls1n00b's Avatar
Default i want 440 rwhp
Hey guys, my t-a made 385 rwhp and 384 rwt with a 222-224 duration .566-.568 lift 112 LSA cam, exhaust,lid and fast 90\90.
I dont want to change cams, i love the driveabillity and torque with this cam.
Which set of heads would be best for this setup?
money is not a limiting factor, and i wonder if trickflow 215 would be badass for this setup?
Old 04-22-2009, 12:40 PM
JCLYNN's Avatar
Hey man I got a similar mild cam, Im making 448 to the wheels, i went with a set of ported 243's i paid 500 bucks just for the stockheads and a ported fast 90 and thats on a automatic. obviuosly i spend most my money on the porting. go to the dyno forum and look up 243 thread and you will see my numbers.
Old 04-22-2009, 12:41 PM
ajw2500hd's Avatar
yea me too!!!! how can we do this!?!?!?!
Old 04-22-2009, 12:56 PM
Red99TA's Avatar
You're going to need some great heads to hit 440 considering that you've got all the bolt-ons now plus staying with the 224 at 385 RWHP. Gaining 55 RWHP from heads alone on a smaller cam isn't impossible by any means but it's not easy either. I'm sure a lot of it will depend on the tune. As mentioned I would go with an LS6 type head like maybe the PRC stage 2.5's or if you've got the money then maybe some AFR's or Trick Flows. Seems the trick flows are making killer numbers and would be your best shot at achieving max power out of your combo. FWIW I'll be installing a bigger cam with AFR 205's and my goal is going to be 440RWHP also but on the LS6 intake/TB.
Old 04-22-2009, 02:29 PM
ls1n00b's Avatar
appreciate your answers guys, i am wondering if the 215 trickflows are better or maybe i should get the afr 205?
i havent seen many results from these heads, especially the 215 trickflows on smaller cams like the one i have.
i was recomended these heads from my tuner
jclynn sounds like you have a factory freak
my car has a shitload of miles, but i guess with the mods i have i should be about average with this cam hp and torque wise?
Old 04-22-2009, 04:29 PM
Michael02hawk's Avatar
Originally Posted by ls1n00b
...money is not a limiting factor.
Since money is not a factor for you, the cash will be well spent into either one of these heads!
My personal choice would to go with a set of AFR 205s with Tony Mamo's added magic touch of porting.
I gained 18rwhp and 15rwtq (under the curve) from just Mamo's porting.
See my post in the Dyno Comparassions section for details.
Old 04-22-2009, 04:33 PM
jpajkos's Avatar
I made 440 with a .232-.238 .646-.613 111 lsa, with a set of Patriot stage 2 243's, unported fast 90/90 with all the bolt on's through my stalled a4.
Old 04-22-2009, 04:52 PM
With valve lifts that high, I would have expected more!
The thing is the original poster stated he did not want to change cams, so we're trying to work within his guidelines.
Old 04-22-2009, 04:54 PM
ls1_sw's Avatar
i made 423 cam only with the ms3 237/242 603/611 112lsa with stock heads i just recently purchased 243's ported 2.5 and fast 90 combo i should be around 460-470rwhp hopfully
Old 04-22-2009, 05:51 PM
Red99TA's Avatar
I don't think anybody is reading the fact that he's KEEPING his current cam!
mitahuoch's Avatar
Im making 426whp with a set of patriot stage2 heads and a custom comp cam 631 intake lift/ 610 exhaust lift on a 234 duration. stock ls6 intake and kooks 1 7/8 inch headers.
Old 04-22-2009, 06:26 PM
corvet786c's Avatar
GET AFR's Milled to 62cc you will get about 40-50 rwhp.
Old 04-22-2009, 07:53 PM
goober35's Avatar
He will be really close on his 440hp goal. With the 224 cam and a kick *** set of ported afr heads and a port matched 90/90 fast intake. Might want to also look into a set of 1 7/8 headers.
Old 04-22-2009, 09:30 PM
ls1n00b's Avatar
so afr205>trickflow 215? also where can i get the heads ported and for how much?
I have pacesetter longtubes,custom y with flowmaster merge and hooker catback. k&n lid, fast 90 with NW 90mm TB.
Should i also get a bigger MAF or do these just cause trouble?
Car is M6 btw.
Old 04-22-2009, 10:03 PM
These are the top two head choices, I dont think one is really better than the other - but, I do know Tony Mamo of AFR, can do one hell of a great port job on his AFR heads. Ask me how I know. I'm sure the trickflows can be ported also, but I dont know by who.
Tony also does an A+ job on porting the FAST 90/92 intakes. I havnt had him port mine....yet.
Call Tony directly at AFR for the details on the port work he does.
Old 04-22-2009, 10:36 PM
hammertime's Avatar
If you can afford it, Tony Mamo @ AFR is the one to do the porting.
Lot's of good information here in the thread Michael02hawk was referring to:
Originally Posted by Tony Mamo @ AFR
Yes....This is the work I do for some of the guys who are looking for every last pony (and are willing to pay for it) and its all done by myself personally by hand afterhours at my home where I have built a really effective work station including a downdraft bench etc.
The reality is as good as our CNC programming is (and anyone else's for that matter short of some ultra exotic programs found in the one off big dollar stuff), in a production environment there will always be room for more in the hands of a very capable cylinder head expert. The fact I designed the original prototype enables me to know exactly what area's to finese that might be sensitive to flow and respond with some gains. Basically, I take a reeaaally good CNC piece and I perfect it essentially.
Tony knows as much about LS1's, and the combination required to make good power out of one, as anyone here. Contact him the the PM link above, and I'm sure you won't be disappointed. He can also help you get the most from your 90/90 setup as well.
Your current numbers may be a little on the low side compared to some of the lofty figures that get thrown around out there. If the mileage is really a factor, a compression/leakdown test would point to the culprit. If it turns out you have a poor valve seal for example, new heads could be the best way to go. If you have compression leaking past the rings, you may need to address the health of the shortblock.
You should have enough cam to reach your goals with a good quality cylinder head. Don't forget that Tony's "Blue Pill" combo is a 224/228 114 cam, just a hair bigger than your cam. With attention to detail and proper tuning, you can get there.
Old 04-22-2009, 10:39 PM
ssick1's Avatar
thats not bad at all bro was it with all the boltons??
Old 04-23-2009, 10:23 AM
jpajkos's Avatar
?? Through a stalled auto? My cam isn't that big to begin with. Im sure if I was an m6 I would've put down better numbers. My final was 444.
Back on point if your trying to hit 440 I would invest in a set of AFR's. Proven performance IMO along with ETP heads
Old 04-23-2009, 10:46 AM
99blancoSS's Avatar
AFR, TFS, Edelbrock, a ported LS6 head or the 5.3's all will net you what you want with the right cam I can help set you up with he proper combo, I'll pm you with some details. I realize you want to keep your current cam, we can work with it not a problem
Old 04-23-2009, 10:56 AM
Detoxx03's Avatar
A set of AFR 205's ported by Tony Mamo will be your best bet
Quick Reply: i want 440 rwhp
