How bad should my h/c 92/92 car run w/o tune?
Old 04-22-2009, 06:10 PM
wilwhite2kss's Avatar
Default How bad should my h/c 92/92 car run w/o tune?
I know the car isnt gonna run good without a tune , but i was wondering how bad? The car doesnt idle that bad, kinda what i expected, but its my first h/c car and i was just curious as to how it should be on power. Should it feel sluggish until the tune or should it still feel strong but idle bad? The car feels way underpowerd. Is this normal for an untuned h/c car? Also , my ls7 lifters are very loud (sewing machine sound). normal for them or maybe a pushrod and preload issue?
Old 04-22-2009, 06:35 PM
conan's Avatar
They can run prety bad. I would NOT go hauling *** down the road untill its tuned. Your sewing machine sound could be from the wrong size push rod. Did you check for length? What size are you running?
Old 04-22-2009, 06:48 PM
This is the setup i am running. Tfs 215's milled to 61cc 7.5 pushrods w harland sharp rr.
Old 04-22-2009, 06:58 PM
LS6427's Avatar
Why would you want to risk damaging the engine?
Old 04-22-2009, 07:02 PM
conan's Avatar
I would think you would need a shorter than stock (7.4'') push rod, with a milled head.
Old 04-22-2009, 07:54 PM
vsocks1's Avatar
I would have guessed shorter pushrods also.
Didn't you do this head cam a few months back?
Old 04-22-2009, 08:10 PM
litle88's Avatar
Due to the different valve angle on the Trickflow heads, you use a 7.500" pushrod. I also asked Trickflow this after Vengeance told me that too, and they were right!
+1 on the WHY run this car UNTUNED?
Especially with higher compression?
You will then be able to eliminate the skipshift, airpump, rear 02's among other things.
Get it tuned please.
Old 04-22-2009, 08:45 PM
vsocks1's Avatar
True...but his heads are milled to 61cc. which makes a difference I believe!
Old 04-22-2009, 08:48 PM
lemons12's Avatar
depends.... can run shitty as hell and not make it around the block... or could pull up to a red light and idle perfectly fine...
BUT!
YOU NEED TO GET A TUNE..
Old 04-22-2009, 09:33 PM
I wouldn't really say I'm running it, I'm just trying to break in the clutch and make sure that the lifters and pr length is ok. Yes this is the car that I was working on a few months ago , nut due to my mothers passing in jan , I am only now getting to Finnish it.
