How Many Of You Have Had Problems W/Cylinder #7?
Old 04-27-2009, 07:41 PM
Xtreme57's Avatar
Default How Many Of You Have Had Problems W/Cylinder #7?
Hey all,
Just wondering how many guys have had problems w/cylinder #7 (specifically w/regards to running lean or low pressure) and what the surrounding circumstances were? (Stock, modded, happened during racing, not racing, etc)
Thanks!
Old 04-28-2009, 11:55 PM
Xtreme57's Avatar
nobody huh?
Old 04-29-2009, 12:38 AM
racer7088's Avatar
Probably 80% or more of the time on engine we get with a bad cylinder especially detonation it is number 7.
Old 04-29-2009, 01:58 AM
Nitroused383's Avatar
When I bought my flow matched injectors they came with 2 injectors that flowed around 1 lb more. I was instructed to install these in #7 and #8 so they would get addequate fuel flow. Sounds like a good idea to me, it looks like all of the air from the intake manifold gets shot straight to the back. You know which runner is at the back of the intake, oh its #7. Chances are #7 is getting more airflow than the rest of the engine and it needs extra fueling to avoid detonation.
Old 04-29-2009, 05:22 AM
Michael02hawk's Avatar
I did the same thing, installed my 2 highest flowing injectors right onto cyl's #7 and #8.
Old 04-29-2009, 06:17 AM
SSdreamz's Avatar
#7 was the culprit when my engine went.... det. took out the rod bearing. AFR 205 heads, Torquer @ cam and supporting mods....
Old 04-29-2009, 10:30 AM
T.A.WS6
Guest
Posts: n/a
i had.
Old 04-29-2009, 10:58 AM
Xtreme57's Avatar
Are these modded engine?
Old 04-29-2009, 11:18 AM
racer7088's Avatar
Mostly stock but both.
Old 04-29-2009, 11:24 AM
Randy WS6's Avatar
My stock motor broke the ring landing on #7 cylinder
Old 04-29-2009, 11:41 AM
dankl's Avatar
#7 cylinder was the death of my LS1...
Lost compression and oil was getting past the ring
Old 04-29-2009, 12:11 PM
Xtreme57's Avatar
Wow ... this is starting to get interesting. Just for the record my car's #7 rings went to sh** after 80k and no mods other than cat back.
Old 05-03-2009, 06:20 PM
Xtreme57's Avatar
BUMP .... anyone else?
Old 05-03-2009, 10:32 PM
roadtrip120's Avatar
I was told from a machine shop, that the cam shaft twists and you have to allow more PTVC on cylinders 7 and 8.
My GF's ls dropped cylinder 5, low compression, oil past the rings.
Old 05-03-2009, 11:14 PM
LSX Mechanic
Damian's Avatar
Yep. Almost every engine I've ever replaced due to failure had something wrong with #7.
They especially run lean w/ a FAST intakes on the car.
Old 05-03-2009, 11:19 PM
dangerjakeray's Avatar
my #7 is the one with the crack in it...
sucks
Old 05-06-2009, 08:54 PM
Xtreme57's Avatar
sucks
Wow. Interesting ...
Old 05-08-2009, 01:40 AM
Xtreme57's Avatar
Bump for others ....
Old 05-08-2009, 07:06 AM
94 s dime's Avatar
I'm with the guy above Cyl 5 low compression and oil past rings
Old 05-08-2009, 07:09 AM
Mightymike2000ss's Avatar
Location: Home town Clive,IA current town FORT BENNING GEORGIA
so how does this normally happen.... my car has 56k and i dont wont to be let down by my ls1
Quick Reply: How Many Of You Have Had Problems W/Cylinder #7?
