Cam swap on high mileage motor?
If you do a cam swap on a motor with 50 or even 100k miles, is it okay to not tear down the motor and replace the cam bearings?
Thanks
Thanks
Thanks
Thanks
werd...110,000 miles did 1st H/C swap at 90K...did my 2nd cam swap at 100,000....runs like a raped ape w/it's *** on fire. stock chain, oil pump. I keep 6qts of royal purple 10/30 in it and just don't turn it over 6500 and she'll last forever....revs and low oil are what kills these motors....anything over 6800rpms and ur risking motor's life.
Originally Posted by Noyzee
No problems. Just keep good oil, and clean oil, you should be fine. Dont forget good springs.
