4" crank,6.125 rods=?
i have a 4" eagle crank and eagle 6.125" rods out of a 408 can i have them installed in a aluminum block? as long as i buy new rings for the .30 bore pistons?
So are you wanting a 408 as well or are you just going to use the parts that came out of the 408? What block do you have or are you getting? If you have and LS1 you cannot do a .030 Bore like SSdreamz said. If your going to get an LS2 then you can do a .030 Bore and still have your 408. Let us know what block you have or which one your gonna get and we can help you out a little more. To go ahead and answer your question Yes you can swap your Crank & Rods over to another LS-Series Engine.
You can typically get away with up to a 4.020" bore with an LS2 but that is pushing it IMO. (Especially on a power adder build.) We haven't seen an issue at all going 4.010". If you are wanting to go .030 over on a 4" bore, you need to look into a 6.0L iron block. However, there really won't be much of a gain in only .010-.020 of bore size difference. At the point you are buying pistons, get them the smallest the block will clean up at. That way you still have room for clean up down the road and keep the sleeves as thick as possible.
Jon
Jon
i have a 408 rotating assem to use the .30 pistons that came with it my only option is to use an iron block otherwise i have to buy pistons for either a 402 or 383? ls2 block being the 402 and the ls1 block being the 383?
thanks for all the help guys
