Adjustment
Adjustment
i have a hellion cam with yella terra rockers i heard some ticking pulled the vavle covers and notice side to side movment just alittle i only have less than 2k onthis setup,can i adjust them
adjustment
yes after warm up.new era did the install.i know those guys do good work.i just thougt maybe they need adjustment after break in.i don;t how many miles i put on them not 1500-1800
If the wipe is set correctly and pushrod measurements are correct, rockers that are not depressing a valve spring when you pull the valve cover will have a slight side to side movement. No major movement though.
If the valve covers are off, check for contact with the valve cover at the roller tip end and the pushrod end. I just finished buttoning mine back up because the valve cover gasket must have settled a bit and I picked up a tick because the roller tip end was slightly contacting the bosses for the threaded holes on the valve covers.
