2500 stall range Cam Suggestions- 98 Formula
Old 04-29-2009, 04:00 PM
Y2KblueZ-28's Avatar
Post 2500 stall range Cam Suggestions- 98 Formula
My buddies 98 Formula's valvetrain just took a crap on him and were looking around to see what kind of cams the guys are running on here with the smaller 2500 stall converters, and hes wanting to go low 12's with a cam. Any suggestions are open to your combos and results thanks.
Old 04-29-2009, 04:29 PM
TooLateVTEC's Avatar
Thats not much of a stall for these cars...I wouldnt put in more than a 224 camshaft...MAYBE a 228 at the most.
Old 04-29-2009, 04:58 PM
02*C5's Avatar
I am running a 232/238 and my stall is 3200 and that is still a bit small for the cam so I would agree no more than a 228.
Old 04-29-2009, 05:42 PM
PREDATOR-Z's Avatar
224/224 .609/.581 111+1 LSA
Custom cam
Old 04-30-2009, 05:39 AM
HTX
HTX's Avatar
you can go low 12's on stock cam if you have full boltons and suspension. I would go with a 224 cam.
Old 04-30-2009, 04:19 PM
Predator Z where can i find that cam at 224/224 you listed and how much for it ? How much do a4 cars get on the dyno with stock heads ls6 intake and boltons, do you know?
Old 05-01-2009, 06:52 PM
Blk_Ws6's Avatar
A stall only help a cam on take off or does it help idle, an cooling to?
Old 05-02-2009, 07:15 AM
HTX
HTX's Avatar
A stall allows it to idle easier, stop easier, and get up and go.
Old 05-02-2009, 08:48 AM
cody161's Avatar
its a custom spec'd cam. you would have to call comp cams and give them the specs so they could grind it for you. Throw atleast a 3000 stall in it, you will hardly even notice the 2500 stall.
Quick Reply: 2500 stall range Cam Suggestions- 98 Formula
