Cam Size
Cam Size
im planning on building a cam only car for right now and i need to know what would you reccomend as a cam from texas speed for a basic bolt on motor im not lookin for sometihing majorly over the top i want a nice sound a good power gains
I'm curious to know as well. I've read the sticky and seen alot of people say it all depends on what you want to do. The problem is that I don't know how to correlate the sizing to what I want to do. I want something that is a weekend town piddler, but absolute bad *** at the same time. I have a couple other DD's. I'm not going to do anything until I get all the exhaust done, so I've got time to figure it out.
I posted this question a month or so ago. The answer I got was TR224 or TR228 cam have been very proven performers with stock heads. I checked the specs & expected power gains on texas speeds site. I wanted something that would give a decent gain, but not too radical. I got the TSP 228 cam package with PRC dual spring kit, hardened pushrods. For the price, nobody else offered this kit with the PRC duals, comes with valve seals & titanium retainers. I also got the ported LS6 oil pump, gasket package, & ARP crank bolt( highly recommend getting this as its longer & makes installing the crank pulley a breeze). I bought an LS2 chain in the classifieds. I just got the install done this morning, I put 60 miles on it so far & it pulls pretty hard. So far I really like this cam, almost stock idle, slight lope with a nice power increase. Texas speeds cam packages are hard to beat, but I am sure Patrick G & Predator Z know their stuff when it comes to cam selection.
With any camshaft you WILL WANT a stall converter or its just not going to act right. It will idle high in park and the car will lunge/jerk pretty bad when you drop it in gear and you dont want that.
If you go cam only I would say get a 224 duration (@.050) or if you want a little more lope go with the 228 duration (@.050).
If your going to do heads at the same time, you could use a 230-ish duration camshaft and use a set of heads that are around 62cc combustion chamber, use an .045 thick gasket to get the compression around 11:1 and you'll be set. An LS6 intake and a set of headers would be a must...even though my car doesnt have them yet.
Either way you go, get the cam on atleast a 112 LSA.
I just installed my 228 cam so only put 60 miles on it. So far, I like it, drives real good, idle is just a lil more lope than stock with the 114 LSA. It pulls hard, thats untuned too. Texas speed says it should be a 40 whp increase. I really like the power I got from this cam. A few recommended this cam, & it was said theres power everywhere with it, I agree. It just depends on what your goals are. From what you seem to be asking, I think you will be happy with the performance with either the 224 or 228 cam. I wouldnt go any smaller than that. Another reason I went with it is if I went too much bigger than .600 lift, ptv clearance becomes an issue. I am getting the car dynotuned next friday so I will post up the numbers it puts down. You will want a stall with any cam you decide on though.
