PTV results?
Old 05-03-2009, 12:40 PM
JPH
JPH's Avatar
Default PTV results?
For anyone who cares, I degreed in and mocked up a motor this am for a customer and here are some ptv results fwiw.
2001 LS1 block
AFR 205 heas (unmilled)
-.007 deck clearance
3.930/.040 cometic
235/242 .621/.610 111+1 (LSL/XER)
cam in @111.25 ICL and 31* @.050 IVO and 6.5* .006 IVO
Checked with solid lifter/soft springs and stock rockers!
PTV clearance= .082 intake .151 exhaust
Hope this helps anyone, Joe
Old 05-03-2009, 12:50 PM
vettenuts's Avatar
Interesting. I recently read that contrary to popular belief, the AFR heads have more valve drop than TFS.
Old 05-03-2009, 01:16 PM
JPH
JPH's Avatar
I hear you. I didn't check that, but maybe next time I will though. Most people DON'T know how to check PTV correctly anyways from what I see. Heres another one for you.
2002 LS1
Stk Heads
Stk GM Head gaskets
Std. Deck (-.006 to -.008)
Crane 236/242 .600/.609 110+2 (HR5/HR5 Lobes)
Cam RETARDED 2.5* 110.5 ICL (for livable ptv, A4 car) needs cut imo.
PTV results= .041 intake w/cam installed straight up
.052+ intake, & can't remember on exhaust, but was ok .100+?
Old 05-03-2009, 01:26 PM
JPH
JPH's Avatar
I will post up some Crane LS1 "quick lift" rocker cam timing results, compared to a stock LS1 rocker also. Lets just say, PTV is on issue when switch from stk rockers to a Crane? (depending on cam design) lol
Old 05-04-2009, 02:49 PM
S10xGN's Avatar
2002 LS1
Stk Heads
Stk GM Head gaskets
I must be one of them. I have 'about' this same setup, a stock '03 350HP Corvette longblock with 241 heads and a Torquer V2 cam. I checked my PTV using a spring light enough to push down by hand, yet not collapse the lifter. Straight up, I had 0.200" and 0.190" on a cam with 0.595" and 0.598" lift. I checked it 10° either side of straight up and saw small (negative) changes. maybe on the order of 0.015" or less.
To me, this is a worst-case scenario with the lifter innards fully extended and pushing the valve stem into contact with the piston. What other way is there to do this?
Russ
Old 05-04-2009, 05:18 PM
vsocks1's Avatar
OEM LS6 block with TFS 215's milled to 60cc with 232/236 .595/.578 113+3 (installed 110 ICL) At 11 ATDC we had about 0.040-0.045 on intake....decided to flycut intake side 0.090 for sufficient clearance!
Old 05-04-2009, 05:51 PM
SweetS10V8's Avatar
I did mine with a checking spring, solid lifter, stock rocker, dial indicator, and an adjustable pushrod. L92 heads, milled .030" on an LQ9 short block.
Its a Comp LSR 219/235 .607/.621 113 +4, I paid extra for Comp to Adcole it for me. So I know exactly how its ground.
I had .090" on the intake and .085" on the exhaust. Im glad I didnt mill them anymore!
Old 05-05-2009, 08:34 AM
00SS6spd's Avatar
Please do, I was doing some research on them and I'm very interested in seeing how the "Quick Lift" design affects PTV. Especially since I'm strongly considering purchasing a set of them in 1.7 ratio for my car, with a setup that I'm wary to push the clearance limits of much farther.
Old 05-05-2009, 08:40 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm sure you could call or PM Tony Mamo and ask him about the valve drop.
Old 05-05-2009, 04:48 PM
JPH
JPH's Avatar
Will do.
Old 05-05-2009, 05:30 PM
SweetS10V8's Avatar
I never understood "quick lift". Excuse my ignorance...
Why wouldnt you just get a cam designed with fast ramp rates? It makes it sound like "quick lift" rockers are made to help slow ramped stock camshafts.
What happens whey you put quick lift on a cam with a agressive ramp?
Old 05-06-2009, 01:09 PM
JPH
JPH's Avatar
The motor really like it and the intake opens about 4-6* sooner!
Old 05-06-2009, 05:32 PM
SweetS10V8's Avatar
So get a cam that opens 4 degrees soon? What happens when you have a cam with an agressive lobe?
Old 05-06-2009, 05:52 PM
OWN3D BY MY PROF!
^ I'm sure you could run into some valve train instability issues with an inadequate spring. You also have to be aware of your PTV clearance like it was previously mentioned.
Old 05-13-2009, 01:27 AM
00SS6spd's Avatar
Will do.
Any update?
Old 03-03-2010, 04:44 PM
JPH
JPH's Avatar
Any update?
I haven't forgotten about the rocker/cam setup. I do it soon.
Old 03-03-2010, 04:47 PM
JPH
JPH's Avatar
True, but the rocker will help the cam act bigger and what not! As far as using a cam with a more aggerssive lobe, you can run into some unstable valvetrain issuses also.
