IDLE clip of TSP Tsunami Cam!!
Old 05-03-2009, 07:36 PM
Vcious04's Avatar
Default IDLE clip of TSP Tsunami Cam!!
Had the SS down for about a month doing some upgrades.
Just finishes installing the following..
TSP Tsunami Cam
Edelbrock 1 3/4 stepped 1 7/8's Long Tube Race Headers
Hutto 3" Stainless X-pipe with 3" Bullet dumps
Lowered 2.5" all around
Holeshot Holestar 15x3.5 Front
Holeshot Holestar 15x10 Rear
28x13.5x15 Hoosier QTP's (yes, took a LONG time to fit without running)
Removed all AIR and EGR crap
Removed front bumper support
Already had..
AFR 205's with Gold Dual's
BBK80mm TB
TR MAF ends
Hardened 7.4 PR's
LS6 Intake (stock)
4.10 Gears
LID & K&N
Tuned by RPM
I will be getting it tuned next weekend, I am going to switch to the Edelbrock Victor series Intake with Elbow for a comparision in power.
I would have to say it sounds incredible now, runs like a BEAST and looks fabulous in my opinion! LOVE IT!!
Old 05-03-2009, 07:48 PM
ramdaspadhye's Avatar
weak....
Sounds nice man!
Old 05-03-2009, 07:50 PM
Vcious04's Avatar
Originally Posted by ramdaspadhye
weak....
Sounds nice man!
Thanks! It's kinda crappy because you can hear how much bass the exhaust has. It just pounds on your chest when standing next to it!
Old 05-03-2009, 08:08 PM
Get some acceleration vids, slow and wot!
Old 05-03-2009, 08:19 PM
97blackz28's Avatar
sounds good, and the car looks very menacing!
doesn't such a tall tire sort or offset having the gears? I would think it would make the gears seem taller. I could be way off base though so...
Old 05-03-2009, 08:29 PM
You n eed bigger gears for bigger tires, but if it was my guess, he prolly doens't have any problem hooking up or gettin down the strip, lmao
Old 05-03-2009, 08:35 PM
ajw2500hd's Avatar
i am thinking of the same cam or the ms3!! let me know what you thing of cam and what it dynos at thanks!!!
Old 05-03-2009, 09:25 PM
Vcious04's Avatar
I will definetly post results!
Old 05-03-2009, 10:49 PM
SLOW 94 LT1's Avatar
Did you trim the fenders at all? Doesn't look like it. I wouldn't be surprised if they rub on the big end. Nice job!
Old 05-03-2009, 11:58 PM
built408's Avatar
nice work, car looks mean as hell!!
Old 05-03-2009, 11:59 PM
Soul Crusher's Avatar
You don't have aa 10 bolt do you? What was involved in fitting something 13.5" wide in the back?
Old 05-04-2009, 07:32 AM
Vcious04's Avatar
I spent probably 10 hours on shaping the inner parts of the fenders and lip. Used several different hammers and plates to get it right. Actually looks pretty good on the inside of the fenders, not all smahed up looking.
So far, just a little bit of rubbing when turning sharp with 3 people in it.
Old 05-04-2009, 07:37 AM
Vcious04's Avatar
Yes, factory 10 bolt. Alot of time and patience. I had to remove the springs front and rear a dozen times to get the stance right.
Old 05-04-2009, 10:18 AM
TooLateVTEC's Avatar
Sounds good and looks mean as hell.
Good luck on the dyno.
Old 05-04-2009, 11:55 AM
EarlSS's Avatar
Awsome sounding setup and car looks very intimidating. I'm sure the dyno numbers will be great! I got a few questions about your setup. Any milling done to the heads? What thickness head gaskets did you go with? Did you have to flycut?
Old 05-04-2009, 12:50 PM
Banned Village Idiot
LS1BLKSS's Avatar
sounds and looks mean as ****
Old 05-04-2009, 01:11 PM
Vcious04's Avatar
Thanks man! I cc'd the heads and came up with 64cc. Head gaskets .40 cometic, no fly cut, stock bottom end.
Old 05-04-2009, 02:56 PM
99Ls1fever's Avatar
Sounds Mean!!!!! What Size tires are you running on the back of that thing?
Old 05-04-2009, 03:08 PM
blownws6_nc's Avatar
sound good, congrat's
Old 05-04-2009, 06:58 PM
avengedws6's Avatar
That thing is mean Jeremy. Loving the way it sounds. So when are u gonna help me with the cam swap in my t/a?
Quick Reply: IDLE clip of TSP Tsunami Cam!!
