dipstick pushing out @ high RPM?
Old 05-04-2009, 10:50 AM
Eagle02's Avatar
Default dipstick pushing out @ high RPM?
I've heard so many stories on what this could potentially be, so I'm coming here to get some more opinions on the subject.
I've got a car that's shooting its dipstick out about 3-4" when its revved past ~6200RPM, usually also spits a bit of oil out (just a mist really) @ the same time.
Is the answer to put a breather on the oil fill, or should I be looking for something more serious?
Thanks for any input!
Old 05-04-2009, 11:06 AM
Eagle02's Avatar
The cam has a big cam in it also... possible that it might need a vac. pump?
Old 05-04-2009, 11:12 AM
Moderator
thechef's Avatar
you can try a breather, but its usually a piston problem
Old 05-04-2009, 11:14 AM
Eagle02's Avatar
Ok, will try a breather. Otherwise I guess a compression check is in order?
Old 05-04-2009, 08:20 PM
Ramairbird's Avatar
I would do a compression check 1st, you might have a broken ring land.
Old 05-04-2009, 08:47 PM
MrElectric03's Avatar
Check your compression and a leakdown test first, are you running a catch can. Everyone has their own opinion on breathers and the pvc system, personally I wouldnt run a breather, always makes the engine a mess and the pcv system with a catch can should work fine.
Old 05-04-2009, 08:50 PM
deelong4002's Avatar
maybe a stuck PCV valve? Does it run ok?
Old 05-04-2009, 11:06 PM
BAMF's Avatar
ya just vent the valve covers into a can with a bunch of steel wool init and a open hole in the top
