How much power at the crank can a stock LS6 support?
Old 05-04-2009, 12:59 PM
ferrari360man's Avatar
Default How much power at the crank can a stock LS6 support?
I have a 2004 Z06 and am ready to order a twin turbo kit for it complete with injectors, boost a pump, and predator tuner... However my question is at the crank how much power can this engine support?
The kit is rated at about 6 psi, and claims to create 530RWHP roughly.
I know I will need to do a clutch, but I am worried about this bein too much for stock internals?
Old 05-04-2009, 01:39 PM
fast01's Avatar
I wouldn't worry about the numbers as much as would cylinder pressure and detonation. 6psi will probably be right on the edge with the compression of the LS6 engine in your Z06. You don't mention an intercooler or meth injection in you post which has me worried about the detonation thing, especially with 10.5:1 compression and the predator tune, imo, is asking for trouble as well. You'll really need a good dyno tune to keep things safe.
Old 05-04-2009, 04:41 PM
The kit does include a intercooler for the car. No, nothing about methonal injection... I said 6 psi, but I believe it is 5 psi. My mistake.
Old 05-04-2009, 06:51 PM
fast01's Avatar
At 5 psi with a proper tune, you should be fine. If you have an intercooler, meth isn't necessary, but it never hurts either! Again, detonation is the enemy, so make sure your tune's up to speed.
Old 05-04-2009, 09:13 PM
well it is the sts kit, which it looks like you are also in the market for
And I spoke with them, and it is in fact 6 psi.
Old 05-04-2009, 09:31 PM
conan's Avatar
I would not just rely on the pedator tune. Go get a dyno tune. The stock bottom end will live at the 530 mark but I would be saving for a forged bottom end and some 72cc heads. The biggest factor is going to be the tune, it may last a while and it might go boom before you know it.
Old 05-04-2009, 10:58 PM
so many mixed opinions... I guess I wont know till I drive it.
Old 05-04-2009, 11:42 PM
fast01's Avatar
I don't think the opinions are really all that mixed, unless your weighing in opinions from outside of this thread. Basically, you should be ok aside from the Predator tune. A dyno tune is really in order.
I actually have an STS kit that I have yet to install because my car was my daily driver until Last December and I couldn't afford to grenade the motor and be without a car, so I was gathering the requisite forged internals. That and the fact that I was seriously injured back in August and am unable to walk due to a shattered femur. Anyway, good luck with your build!
