What did everyone use to seal their rocker bolts with?
I'm still seeing some blue smoke at startup and sometimes even at idle since the heads install. I hope the rocker bolts not sealed is the problem and will fix the oil burning?
Thanx...
Thanx...
Rocker bolts sprayed cleaned of oil with brake cleaner. Heads were new, so the rocker bolt holes did not need cleaning.
Good amount of black silicone sealant on the intake rocker bolt threads and install.
No oil burning at all ...
Originally Posted by Tally TransAm
im curious to the answer to this as well
when i did mine i used black high temp rtv
is it better to put the rtv on the threads of the bolt itself, or put some in the bolt hole in the head?
