Anyone ever hear of Bearing washing out cause of to much oil psi?
Old 05-05-2009, 06:02 PM
BigRich954RR's Avatar
Default Anyone ever hear of Bearing washing out cause of to much oil psi?
I cant believe this but someone told me to much oil PSI can wash out the bearings ?
Old 05-05-2009, 06:06 PM
crainholio's Avatar
Someone told me he's as wrong as a 3-dollar bill.
Old 05-05-2009, 06:57 PM
DaveX's Avatar
He might have been talking about the problem the old big blocks had. At high rpm, too much oil pressure and it would pump all the oil to the top of the motor, not drain back down fast enough, and starve the bottom end. I have never heard of this being a problem with LS motors.
Old 05-05-2009, 07:40 PM
SOMbitch's Avatar
Oil pressure and oil volume are often confused......Oiling has been a problem on these engines and is why the LS6 superseded the LS1......
Old 05-06-2009, 06:20 AM
DaveX's Avatar
Can you elaborate on that a little? What oiling problems do LS1's have, and what changes did they make on the LS6 to address it? This is the first I have heard of this. I thought the LS6 was basically the same other than a minor change to the block for strength (yes I know the heads and cam are different).
Old 05-06-2009, 08:26 AM
crainholio's Avatar
The LS6 block has windows cast into the crankcase area to allow better ventilation of gaseous pressures, located between each crank journal space. It's possible this design was carried into the LS2 and up blocks but I haven't looked into it. Very little to do with "oiling" per se, just mananging crankcase pressure better.
Apart from that, I've not seen any other oiling improvements designed into the LS6. The routing of pressurized oil is identical in every GM drawing I've seen. The only documented design change involving oil I saw was the compression ring packs, which resolved oil consumption problems from ring flutter.
As far as oiling having been a problem on the LS1, I'd like to see documentation of that claim. Here are two examples proving the opposite:
The old ASA racing series used LS1 crate engines with GM's ASA camshaft, the only problem they documented early on was the connecting rod bolts and this was addressed in the 2001 production change to upgraded bolts.
Another good example was the C5 Vettes at Bondurant Racing School, just plain old LS1 engines getting the snot beaten out of them with no oiling system modifications. They blew two engines right off the bat, same failure mode (#4 rod bearing if I recall right) so they consulted with GM and the result was a switch to thicker oil. Mobil-1 15W-50 synth. No oil cooler, no aux pressurization system, just thicker oil. No further engine failures from oiling problems, and the car I abused...uh, drove...was showing 300-310degF oil temps on the DIC most of the track time.
Google ASA + LS1 and you'll find more info, this one is a good start:
http://www.engineering.com/Library/A...wn-effect.aspx
Old 05-06-2009, 02:41 PM
SOMbitch's Avatar
In road racing apps there have been instances of spun bearings due to the pump nearly emptying the pan at sustained high rpm and the g force sloshing the oil away from the pick up tube.
It is why there are some aftermarket pans available with different baffles designed to help keep more oil around the pickup area.
It why most RR and AX guys run 6.5-7 qts of oil in a 5.5qt f-body pan.
It is why some do the lifter tray mod to speed up the return of oil to the pan.
It is not usually a problem in a street/strip car but in extreme apps it can POSSIBLY be a problem.
Oh... and a vette has a different pan too so maybe that helps over the f-body pan...
Old 05-06-2009, 03:53 PM
crainholio's Avatar
All true statements, but none of which is indicative of an oiling problem inherent to the LS1 engine which, you claim, caused the LS6 to supersede it.
Old 05-06-2009, 06:22 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
LS1s have issues with high RPM windage. A lot of the more track oriented vehicles switch to the Canton pan or a dry sump setup to control oiling and gain some power in the process.
Old 05-07-2009, 10:48 AM
racer7088's Avatar
The ASA engines are a modified drysump design to keep the engines alive. They do not use the OEM oil sytem but do use stock pump for a pressure only pump. LSx design has problems foaming oil from excessive windage and poor oil drainback.
Old 05-07-2009, 10:49 AM
racer7088's Avatar
Arrow
Not gonna happeen with modern bearings. This was suposedly an issue with really old soft babbit type bearings and very high oil pressure.
Old 05-07-2009, 11:07 AM
Nice thanks guy for all the great answers. Is there any ways to help the LS engines with oil drain back other then going with link bar lifters to get rid of the lifter trays ?
Old 05-07-2009, 11:46 AM
05gto60's Avatar
someone showed a pic of holes drilled into the lifter trays to help with drain back. dont know how much it actually helps though
Old 05-07-2009, 02:40 PM
SOMbitch's Avatar
It makes sense to me it would help with drainback but at the same time might weaken the tray. Dunno???
I decided not to do it when my heads went on.
Old 05-07-2009, 03:04 PM
05gto60's Avatar
i never saw it till after my motor was together or else i might have done it.
how much oil actually gets stuck there though?
if it was a big issue, you think GM would have pull little holes in it from the factory
Old 05-07-2009, 04:04 PM
OWN3D BY MY PROF!
^ GM also designs vehicles with only their performance ideas in mind. They don't expect the average buyer to throw a large cam in there and spin it to 7500 rpms.
Old 05-07-2009, 04:50 PM
05gto60's Avatar
yes, but i still dont understand how THAT (the trays) would be a major factor in the drain back process. at 7500 rpms, wouldnt it be more about flowing too much oil and not that some is stuck in a lifter tray?
im not trying to argue, i just dont understand how the lifter tray could be a big restriction. does that much oil actually get trapped there?
Old 05-07-2009, 05:24 PM
racer7088's Avatar
Once the trays fill up with the amount of oil they are going to hold it still just spills over from then on anyway so I don't thing it is a big deal really.
Old 05-07-2009, 05:27 PM
crainholio's Avatar
Yup, and the up/down motion of the lifters should have the effect of ejecting some (if not most) of the oil trapped in the trays.
Old 05-07-2009, 06:21 PM
As rpms goes up so does the load and forces on the bearings so you need more oil to get to them for lube/cooling. yea why there was a old rule of 10 psi for every 1k rpms. The LS oil pump pumps enough oil to start to empty the pan which might cause it to suck air if its not draining back fast enough.
The lifter trays not a big restriction but every little bit helps
Quick Reply: Anyone ever hear of Bearing washing out cause of to much oil psi?
