Question about removing/installing stock rockers.
I'm fixin to remove my heads on my ls7 project to send them to get milled.
I'm gonna step up to a bigger cam while i have the heads off too. I'm still gonna use the stock rockers. My question is, when i get the heads back and bolted on. Can i just simply put the rockers back on and torque them down?Or do i need to do it in some kinda valve or cylinder sequence? I read sumin about havin to manually turn the engine over by hand to make sure the valves are shut in the head?
It's best to torque them down when the respective lifter is on the base circle. I usually just turn it over by hand (with the plugs out) and do a visual on each one to make sure it's on the base circle before torquing.
You should check with you cam designer for the amount of lifter preload he suggests. After you measure the pushrod length with your new cam and milled heads installed you can order the correct length and get them in a couple of days. While you are at it, ask your cam guy which pushrods to use, by brand, diameter and wall thickness (or part number).
Good luck.
Jon
You are going to measure for the correct pushrod length with the new cam, correct? The new cam will have a smaller base circle if it has more lift, so best pushrod length will change.
Good luck.
Jon
Good luck.
Jon
Also guys i have another question. I have done 1 cam swap before but the engine had the heads on it. I'm gonna be swapping cams w/o the heads on this time and i was wandering if this changes anything? What extra things am i gonna have to/not have to do since the heads are off. Thanks
Tighten to 22lbs, spin motor. tighten to 22lbs again
Having the heads out only makes it easier. no real changes, don't have to worry about the lifters dropping tho since you can just remove them
Also try to make sure the tip of the rocker stays centered on the valve (left to right) when you are tightening the rocker. I've seen people just reef the bolt down and pull it into place and it makes me cringe. It is aluminum you are tightening into so a little prevention is worth...
