crank no start. not sure where to post
Old 05-08-2009, 08:48 AM
2000NavyZ's Avatar
Default crank no start. not sure where to post
i had the car running for 15 minutes prior, shut it off for about an hour and went and started it. After about 10-15 seconds of running, it just died. now it just cranks and wont start. its a 347 w/ 37lb injectors,fast 90/92. it has ran just fine for the past 3 weeks since doing the swap. any ideas? all the fuses/relays tested out fine. Dont think its the fuel pump, you can here it when you turn the key on and there appears to be fuel in the lines.
Old 05-08-2009, 10:11 AM
adam1803's Avatar
check for spark, also check the ground wires on the back of the heads. I had one break and it wouldn't start.
Old 05-08-2009, 10:24 PM
2000NavyZ's Avatar
it ended up being a bad ignition relay.. thats the second time.
