Very low oil presure when hot!! help!
Old 05-10-2009, 11:10 AM
Johnnystock's Avatar
Default Very low oil presure when hot!! help!
My car has new issue; the oil pressure is dropping around 40-50 when hot instead of a steady 60 when cold. But it dropped down to 10-15psi when I did a burnout and let off the throttle but it was getting back to 40-50 when giving throttle...oil pump is gone or what??
Old 05-10-2009, 11:11 AM
And I did a recent oil change(TTP did it with royal purple), I was running mobil one before. The problem got worst after a 550miles run..Good part of the run was done at very high speed and RPM!!
Old 05-10-2009, 12:26 PM
First Collision's Avatar
What oil pump are you running? 40-50 is normal when hot.
Old 05-10-2009, 01:04 PM
Not sure, never had a look at it but I guess its a ported one...
I'll try to change the filter in case the oring was damaged and maybe the filter is a crappy one.
Old 05-10-2009, 01:05 PM
What bothers me is I got a big drop to 10-20 after a burnout and I was scared to damage something!!
Old 05-10-2009, 01:36 PM
2000NavyZ's Avatar
check out the o-ring on the pick up tube. common issue
Old 05-10-2009, 11:47 PM
So youre telling me I need to tear down all the front to do that??That sucks!!
So the way to get there is this??:http://www.ls1howto.com/index.php?article=4
..minus the removal of the oil pump and ****??
Tempting to swap the cam while in there...
I'll try to change my oil filter first in case
