New motor, how long to see oil pressure?
Old 05-11-2009, 11:54 PM
letsrunem's Avatar
Default New motor, how long to see oil pressure?
Should I be able to crank it for awhile and see oil pressure? Or does it need to be running?
Old 05-12-2009, 12:19 AM
therobman's Avatar
im pretty sure it needs to be running take out the fuel pump fuse and crank it to get some oil going i did it 2 times like 10 second intervals. then just started her up and oil press came up with in 5 seconds
Old 05-12-2009, 12:24 AM
letsrunem's Avatar
Gotcha. I had cranked it for about 5 seconds and was a little worried the gauge still read zero. Definitely don't want to hurt anything.
Old 05-12-2009, 12:53 AM
therobman's Avatar
yea id crank it for 10-15 seconds to get it oiled up then fire her up
Old 05-12-2009, 08:54 AM
Aaron1017's Avatar
I had to crank mine a good 30 seconds after a head/cam/oil pump swap before seeing any pressure on the gauge. When cranking, I disconnected the fuel pump and had no spark plugs in to make it easier to turn over. I wiped the cylinder walls down with assembly lube when putting everything back together.
Old 05-12-2009, 10:20 AM
SLOW 94 LT1's Avatar
Your gauge might not show anything while cranking, keep that in mind. Mine did not and I did 3 10-12 second bursts. Soon as we plugged in the injectors it fired right up and immediately had 60+psi.
Old 05-12-2009, 12:11 PM
PAGregSS's Avatar
Leave out the spark plugs so it's easier for the starter to turn the engine as it won't be working against the compression. It'll seem like an eternity, but it will take a good 30 seconds. It will build fast once you start seeing pressure.
Old 05-12-2009, 09:52 PM
bigboykilroy's Avatar
same here about 30 sec, remember to take out the fuel pump relay and disconnect the coil harness on both sides.
Old 05-13-2009, 12:16 AM
f-bodyguy's Avatar
i just dropped mine in last sunday i turned it over for about 10 seconds with the coil packs unplugged plugged them in and fired up shot up to over 60psi then bumped the trottle a couple times to get oil to the valves
Old 05-13-2009, 06:50 AM
PAGregSS's Avatar
Now think about what would have happened if you had not gotten oil pressure. Your engine would have been running with no oil.
Old 05-13-2009, 01:50 PM
sman's Avatar
X2 Same issue here, nothing on the gauge, none of the gauges on my cluster work while starting the car. Once running however, it instantly had 60+
