Tr 236
Old 11-05-2003, 06:42 PM
HOTROD98Z's Avatar
Default Tr 236
Does anyone have any experience with this cam, I know its been out for a little while but haven't seen hardly anyone with numbers on this cam, is anyone running it yet?
Old 11-05-2003, 06:54 PM
LS1Tech Sponsor
Slowhawk's Avatar
A few people are running it.I personally gained 18hp/8tq from my TR224.
Old 11-05-2003, 08:02 PM
HOTROD98Z's Avatar
Pretty good gains id say. Does it lope a lot more than the 224, what lsa is the 236 ground on?
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
How does it drive compared to the TR224? Bottom end?
Old 11-05-2003, 08:48 PM
LSX Mechanic
Damian's Avatar
18HP and 8TQ up top, but how about through the entire RPM range where it REALLY matters?
Old 11-06-2003, 12:46 AM
Moderator
LIL SS's Avatar
I'm in the middle of putting one in right now with stock heads. It should be running by sunday. I will be doing some tuning for Ltrims and things before going to the dyno. Gonna try and dyno on the 18th if possible. I'll be sure to post results and a sound clip.. BTW, I will be spraying a 100 shot on it as well.
Old 11-06-2003, 07:46 AM
LS1Tech Sponsor
Slowhawk's Avatar
Took alittle time to get idle good at 950rpm.Now it idles with very little lope.Hot and Cold starts are perfect.
The car needs a little more gas to take off,nothing major.Drivabilty is just as good as the 224.I can lug the motor at 1500rpm with no problems.The Cam is more suited for 4000rpm and up.The graph look the same as the 224 below that then the 236 takes over above.Peeks at the same points.
At the track I gained 3mph.
