Stroker setup?
Stroker setup?
Will a 4.0 crank fit in you stock ls1 5.7 block with machine work, or what size crank would you use to build a 383, that will work in your stock block with of course some honeing and boring.
Is there more life in the motor useing a iron block with a 4.0 stroker setup, or is it the same with your stock alum block? No FI, and No Spray.. NA motor
Thanks
Thanks
