the correct way to install head studs
I then let the heads "settle" overnight and retorques them all in sequence. This is what I was told to do!
Here are some portions of a PM answered by member -Joseph- here who's posts here are always helpfull when I posed this same question to him:
you can add a very minute amount of torque to the stud to keep it from backing out, but I never worry about that as once it has torque on it; both sides of the stud aren't going anywhere.
With any Alum block, a retorque helps out after a few heat cycles, but isn't necessary. I go back over them on the engine stand an extra pass at final torque as usually the middle 6 studs/bolts will settle in as the outer bolts are torqued.
I use the factory torque pattern but with ARP studs or bolts I use stepped torque values, 30-50-70 for bolts, and 35-55-80 lb ft for studs; both with ARP lube. The bevel on the washer goes up towards the ARP nut.
and regarding the smaller studs up near the intake:
23lb ft with moly lube or 28lb ft without. I often just use oil on those bolts as they are not as critical for torque settings, and it seems the under-intake location attracts dirt; so lack of moly seems to make less mess the next time you tear it down.
This info was helpfull to me and I dont think he will mind my sharing it.
